dogbert88
Apr 19, 2019Aspirant
Errors accessing or linking to many web pages RBK23 AC2200
When I am using the ORBI WiFi connection and I try to link to many web pages I receive an error message or a request for "authentication," but when I switch to my Spectrum 2G or 5G WiFi connection, I ...
- Apr 22, 2019It worked! Many thanks for your help. I can't seem to get this website to accept the "accept as solution" entry, but your suggestions, particularly the change to AP mode, worked like a charm. Again, thank you for your help; it's nice to have Dudes Named Ben out there to provide expert assistance to us deplorables.
Apr 22, 2019Guru - Experienced User
What is the IP address the Orbi router is getting from the Modem/Router?
Try accessing the RBR at 192.168.1.1. If you can't access the RBR, then the RBR is getting a different IP address or maybe in conflict with the up stream router.
You need to try one of the 2 suggestions...
If the Orbi IS connected directly to the ISP Modem, then you should be able to access the RBR at orbilogin.com or 192.168.1.1.
You might power cycle OFF the modem, factory reset the RBR, Power ON the ISP modem. With a wired PC connected to the back of the RBR, use a web browser to access orbilogin.com or 192.168.1.1. Ensure your PCs networking is set for auto obtain IP addressing.
dogbert88
Apr 22, 2019Aspirant
- FURRYe38Apr 22, 2019Guru - Experienced User
Good to hear. Glad that worked for you.
Might exit the site. Clear browser cache then log back in and set the solution.
ENjoy. :smileywink:
