BikerNeil
Dec 19, 2017Follower
Ethernet Backhaul - RBK40 or RBK50
If using Ethernet backhaul, is there really any difference between RBK40 and RBK50? The main difference between the two seems to be the wireless backhaul (and USB port). I'm planning to purchase one ...
DarrenM
Dec 21, 2017Sr. NETGEAR Moderator
The range is a little lower on the RBK40 than the 50 and like you said the usb port other than that they are the same.
DarrenM
