Mountain20
Jun 17, 2019Aspirant
Ethernet backhaul - some satellites connected via ethernet, some not
Having challenges covering entire house - lots of double walls with sheer panels and stucco. I have an Orbi RBR50 with 2 Orbi RBS50 satellites connected wirelesly. I have moved RBR50 to differen...
Jun 18, 2019Guru - Experienced User
For wired back haul:
Set up IP address reservations for each satellite and devices on the router as you add them to the router. The satellites need to be set up via wireless first. Then connect 1 satellite at a time to the ethernet LAN cable. Wait 5 minutes and the top led on the satellite should turn on BLUE. Set up an IP address reservation for the 1st satellite. Continue to do the same thing for the 2nd satellite. Then follow up with your devices.
Mountain20 wrote:Having challenges covering entire house - lots of double walls with sheer panels and stucco.
I have an Orbi RBR50 with 2 Orbi RBS50 satellites connected wirelesly. I have moved RBR50 to different locations with some better responses but still spotty to cover entire house 5000+ sq feet over 3 stories and spread across 2 buildings.
I'm thinking of getting 2 more satellites and have the following:
- 2 satellites connected wirelessly to RBR50 (cannot easily get ethernet to these spots)
- 2 satellites connected via ethernet backhaul (can run ethernet to these locations)
is there any issue with having 2 satellites on ethernet backbone and 2 wirelessly connecting to RBR50 router?
thanks
Mountain20
Jun 18, 2019Aspirant
Thanks. Any suggestions on setting up the IP address for each satellite? I see the IP address in the Orbi mobile app, but not sure how to set it static when there are over 26 devices connected to the network. Thanks again
