Treyhound
Aug 31, 2022Aspirant
Ethernet backhaul after point to point long distance wireless bridge
I currently have a barn that is too far of a distance for a wireless backhaul for RBR50 and RBS50. Instead of running a very long cable to the barn, I got an avalon point to point long distance wirel...
- Sep 01, 2022
So here is the long story. I went home and somehow the barn satellite had connected with wireless backhaul to the router even with the distance of barn to house. When I looked at connected devices on the barn satellite, it showed both point to point hardware IPs and MAC addresses connected wired to it. Since they were recognized I just did a reboot of everything and the next time it came on it worked as a wired backhauled satellite no problem. I have no clue what the issue was but the ole unplug it and plug it back in seemed to change things. Thanks for all suggestions.
Treyhound
Thanks for the response, I see you on Reddit and here. I appreciate it. I am Cat6 everywhere and the point to point is rated at 1Gbps. When I connect my laptop directly to the point to point in the barn I get the full transfer rate. Is there a way to login directly to set settings for individual RBS for the Ethernet backhaul? Thanks again for any suggestions.
Aug 31, 2022Guru - Experienced User
RBS traffic is pretty specific between the RBR and RBS. If there is anything blocking this flow, the RBS won't sync properly. Might see if there is any settings on this p2p device that could help unblock this data flow...
To check to ensure the RBS is working over ethernet, take the RBS to same room or near the RBR, wirelessly sync it first, then connect it over ethernet there with a LAN patch cable. Check the RBRs web page and make sure the RBS shows as a wired connection after this.
