Treyhound
Aug 31, 2022Aspirant
Ethernet backhaul after point to point long distance wireless bridge
I currently have a barn that is too far of a distance for a wireless backhaul for RBR50 and RBS50. Instead of running a very long cable to the barn, I got an avalon point to point long distance wirel...
- Sep 01, 2022
So here is the long story. I went home and somehow the barn satellite had connected with wireless backhaul to the router even with the distance of barn to house. When I looked at connected devices on the barn satellite, it showed both point to point hardware IPs and MAC addresses connected wired to it. Since they were recognized I just did a reboot of everything and the next time it came on it worked as a wired backhauled satellite no problem. I have no clue what the issue was but the ole unplug it and plug it back in seemed to change things. Thanks for all suggestions.
Sep 01, 2022Guru - Experienced User
Sounds like it needed just a reboot of everything to get it working. Glad it worked.
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Treyhound
Sep 01, 2022Aspirant
So I had rebooted the entire system multiple times, I think it had something to do with the wireless backhaul somehow connecting first then the reboot worked. Anyway, marked as solved and thanks to everyone.
