Boatguy54
Dec 20, 2017Guide
Ethernet backhaul in AP mode
I have one RBR50 in AP mode, wired to a Cisco RV235 router.
One RBS50 satellite via wireless backhaul.
I just obtained a second RBS50 that can be connected via ethernet. The support page shows the satellites being connected via a LAN port, which makes sense since normally the RBR50 will be connected to a modem or internet source.
Do I need to connect my RBS50 through a second ethernet connection from the RBR50 to the router, or is the WAN connection on the RBR50 to the router going to find the RBS50 connected to the same router?
1 Reply
- DarrenMSr. NETGEAR Moderator
You can connect the RBS50 to either the RBR50s second LAN port or to the lan port of your first satellite.
DarrenM
