greenwell01
Feb 21, 2019Aspirant
Ethernet Backhaul issues
Hi guys,
hoping someone can help. I have my orbi router set up as an AP and I initially connected two satellites to it wirelessly. Later I connected them both with ethernet cables.
I have how...
Feb 21, 2019Guru - Experienced User
What FW is currently loaded?
Where you seeing this same behavior before changing to wired connections with the satellites?
What is the Mfr and model# of the ethernet switch if one is in the configuration.
Daisy Chain
greenwell01
Hi,
thanks for getting back to me.
The loaded Orbi FW version is : V2.2.1.210
I didnt test the wireless setup in the same way as the locations and building wont allow a wireless connection at that distance. I could try if they are all in the same room but I guess that would be defeating the purpose.
I have a netgear JGS524E switch to which both the router and satellites are connected.
I have also deactivated Daisy Chaining but has made no difference to the issues.
Thanks
