greenwell01
Feb 21, 2019Aspirant
Ethernet Backhaul issues
Hi guys,
hoping someone can help. I have my orbi router set up as an AP and I initially connected two satellites to it wirelessly. Later I connected them both with ethernet cables.
I have how...
greenwell01
Hi,
thanks for getting back to me.
The cables are good. I just recently had them checked and there were no issues found.
There is a switch in between but I've tried multiple swithches and get the very same results.
The strange thing is that I know the satellites are working. I am connected to the lan port of one of the satellites right now and it works fine. Also when connected wirelessly to a satellite I have internet access but I have the symptons I mentioned before.
Does the connection type show "Wired" on your system?
ekhalil
Feb 22, 2019Master
Yes, the connection type shows “Wired” in my system.
Please try to temporarily connect the nodes with a direct cable and see if the connection type will change to “Wired”. The system should recognize the correct connection type before you can get full performance from the system.
Please troubleshoot the connectivity issues.
