greenwell01
Feb 21, 2019Aspirant
Ethernet Backhaul issues
Hi guys,
hoping someone can help. I have my orbi router set up as an AP and I initially connected two satellites to it wirelessly. Later I connected them both with ethernet cables.
I have how...
Feb 22, 2019Guru - Experienced User
After elliminating this switch to test your system. Check to see if there is any IGMP protocol features that you can disable on this switch. Others have mentioned that disabling IGMP on managed switches resolves issues with Orbi. However you may still see issues with the Green Ethernet features. This featuere doesn't work well with Orbi.
If you need a switch, try NG GS105/108/1600 series switches, good non manged non green ethernet switches.
greenwell01 wrote:
Hi,
thanks for getting back to me.
The cables are good. I just recently had them checked and there were no issues found.
There is a switch in between but I've tried multiple swithches and get the very same results.
The strange thing is that I know the satellites are working. I am connected to the lan port of one of the satellites right now and it works fine. Also when connected wirelessly to a satellite I have internet access but I have the symptons I mentioned before.
Does the connection type show "Wired" on your system?
greenwell01
Feb 24, 2019Aspirant
Hi All,
Thank you for your great support.
So I tried with a unmanaged switch (GS108) and unfortunately there was no change.
However when I connected the two satellites directly to the router (without a switch in between), the connections finally showed up as wired and all the issues highlighted below were gone.
Its not ideal as it means having the router orbi in the cellar (thats where all lan cables from the rooms end) which is a waste of an access point.
Thanks again.
Thanks again.
- FURRYe38Feb 24, 2019Guru - Experienced User
Possible the switch you tried is also not working well. If the direct wired is correctly seeing the satellite with out the switch, you might give a different switch a try. There were a couple of different versions of the GS108.
And you did have Daisy Chain disabled when the satellites were connected?
greenwell01 wrote:
Hi All,
Thanks again.- greenwell01Feb 24, 2019AspirantHi,
Daisy Chain was/is disabled.
Thanks- walkerxFeb 24, 2019Guide
