greenwell01
Feb 21, 2019Aspirant
Ethernet Backhaul issues
Hi guys,
hoping someone can help. I have my orbi router set up as an AP and I initially connected two satellites to it wirelessly. Later I connected them both with ethernet cables.
I have how...
Feb 24, 2019Guru - Experienced User
Ok, was checking. Any un managed, non green ethernet switch shouldn't implede how satellites are reported though. Also could be a lan cable as well thats not to spec.
You might give the beta FW a try as well.
Good Luck.
