BigBlue_007
Jul 10, 2018Aspirant
Ethernet Backhaul kills LAN traffic *partly*
Hi,
my issue is not really the same than the one in the "Ethernet Backhaul kills LAN" topic, so I decided to open a separate topic for it.
My RBR40 router + RBS40 satellite were working w...
Jul 10, 2018Guru - Experienced User
So of wired back haul isn't a problem, why did you revert to wireless back haul?
Maybe a diagram of your configuration and how things are connected would be helpful for us to understand your situation better...
