Erwin_S
Jun 23, 2018Aspirant
Ethernet backhaul not working?
Hi,
I’ve installed my Orbi system today, main device as Router.
Since the distance between the Router and the satellite is too far, I decided to use an ethernet backhaul.
Initially sync...
Erwin_S
Jun 24, 2018Aspirant
Hi,
I think I did juist that, only I did not connect the satellite directly to the route using a cable.
I simply connected the satellite to the wired lan to which the router also was connected.
Will this allow me to disconnect the satellite afterwards, so I can reconnect it to the cable I was initially planned?
The setup I’m planning for is described in the manual as in attached picture.
Erwin
ite
Jun 24, 2018Guru - Experienced User
The direct connection to the router is a prelimiary step to ensure the satellite works on wired back haul. Once you get it set up using this menthod, yes, you'll be able to take the satellite to it's final remote location and connect it up with a NON managed switch in between the router and satellite. I use this same configuration as well.
- Erwin_SJun 24, 2018Aspirant
Hi,
sounds like a plan...
Will do that tomorrow evening, and will let you know how it went.
Erwin
