angelobodetti
Jan 20, 2019Aspirant
Ethernet backhaul on only 1 satellite
Hi all - I have an Orbi 3 pack (1 router and 2 satellites). Am I able to use Ethernet backhaul on just 1 satellite and leave the other wireless? Is anyone doing this?
angelobodetti
Jan 21, 2019Aspirant
Thank you.
Right now it’s set up wirelessly. To change over do I just plug it in to an Ethernet port or do I need to do some sort of configuration?
Jan 21, 2019Guru - Experienced User
When connecting the satellites via wired back haul, connect 1 satellite first via wireless, then once you get the BLUE led on top of the satellite, connect the LAN cable between the satellite and Orbi router. Wait for up to 5 minutes for the top LED to turn BLUE. Once this is done, do a IP address reservation for the satellite ON the Orbi router. Save and apply.
Connect all follow on satellites using the above method for additional wired satellites.
Once all is connected and running. Place satellites in remote locations with there LAN cable connected and turn ON.
Be sure that Daisy Chain is disabled when you have the satellites connected.
angelobodetti wrote:
Thank you.
- 074Feb 18, 2019Aspirant
Guys looking for some advice trying the Ethernet backhaul on my set up, modem is connected to Orbi via internet connection, LAN 1 on Orbi Router is connected to 24 port gigabit switch, everything else connected to gigabit switch, yet I am still only getting between 3-400 mbps on a 1 gig connection, if I connect everything to switch I get the same speeds but am unable to connect to App or Orbi login site, daisy chain is switched off, am I doing something wrong here? I have two satellites (RBK 53 Set Up). Satellites are showing as wired with good on the backhaul page on log in. I am also set up in access point mode and everything is up to date firmware wise
- ekhalilFeb 18, 2019Master
Please check here if this is similar to your case?
https://community.netgear.com/t5/Orbi/Web-login-won-t-display/m-p/1707509/highlight/true#M52600
- FURRYe38Feb 19, 2019Guru - Experienced User
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
What is the Mfr and model# of the ethernet switch if one is in the configuration.Try enabling Beamforming and MIMO.
Daisy Chain, Fast Roaming, IPv6
- 074Feb 19, 2019AspirantIt’s set up in AP mode, tried disabling beam forming, MUMMI and daisy chain modes also, I then reset Orbi and connected in router mode with no cables and enabeled daisy chain etc and there is very little difference in speeds, wire is indicating 960 mbps from switch. router is fritz box 7560, everything seems to be connecting at the 2.4 ghz band for some reason, house is two story small house so Satelites & Router should be fine, switch is Netgear 24 port switch unmanaged (NETGEAR GS324 24-Port Gigabit Ethernet Switch), hope this helps my head is wrecked with this
