laistrogian
Dec 16, 2020Aspirant
Ethernet backhaul on Tenda SG 105 / 108 series?
With non-managed non-green switch being harder and harder to find, and my plan to run RBK 22 on ethernet backhaul, I'm currently searching for a switch that could work
Unfortunately, I'm not in the US with awesome return policy so I can't simply buy 3-5 switches and return ones that don't work.
Currently eyeing the Tenda SG 105 or 108, since there's nothing on them that says it runs on 802.3AZ green features and it's also unmanaged
Does anyone has any experience running with these tenda switches or similar tenda products and if they work?
Suggestions regarding the latest gen switches that works with orbi is also appreciated (since it's close to impossible to find older gen switches in indonesia)
Cheers
NG GS-105/108v4, D-Link DGS-105/108 and HP ProCurve 1400/1800 series switches work for Orbi systems.
- laistrogianAspirant
I could get the DGS 108 in here, but doesn't the latest revision include 802.3AZ green features in it?
If you can find v4 versions of the switch online some place.
