bubble_13
Jan 09, 2023Follower
Ethernet backhaul over point to point wireless connection
I have a RBR50 + 3 satellites. One of the satellites is a remote building and the mesh is struggling to maintain a decent link to that satellite because of the distance and walls between satellites. I'm wondering whether I can use a point to point wireless connection using something like two TP-Link CPE710 antennas to create a link between the satellites that they (the satellites) would just view as wired ethernet connection / backhaul ??
I can't get a wired connection over there without digging up my drive, and the remote building is on a different electrical distribution panel than the house (preventing a power line type solution).
Am also trying to avoid spending £250+ on an external capable satellite (like the RBS50-Y).
Any ideas / suggestions or help would be much appreciated ??
David.
1 Reply
You should be able to do so. I've never done it but seen it posted on here before successfully.
