Retired_Member's avatar
Retired_Member
Sep 04, 2020
Ethernet backhaul RBR40 and RBS20
I have had my AC2200 with two satellites for 4-5 months now. My router RBR40 using firmware V2.5.1.22 is set up in router mode connected directly to the Arris modem, one satellite RBS20 with firmware...
  • plemans's avatar
    Sep 05, 2020
    Try this for testing.
    Use a shorter 6-10ft ethernet cable directly connected from router---satelilte.
    see if it works. If it sync's/configures properly, then its a cable issue (usually the ends).
    If it doesn't, then it could be a device issue.
    are you going through a network switch? Or is it wired directly to router.
