conradh
Oct 24, 2020Aspirant
Ethernet Backhaul RBR53
I have 3 satellites. One outside in the garden, daisy linked to an internal satellite. The internal satellite backhaul is over WiFi. One other satellite is on the other side of the house, the wifi si...
GMoGoody8
Oct 24, 2020Luminary
Check to see if your switches or devices between the RBR and RBS support Green Ethernet standard(802.3az). For some reason the Ethernet backhaul doesn’t play nice with devices supporting that standard. There are numerous reports all over this forum about this.
- conradhOct 25, 2020AspirantThans you. I will check.
- conradhOct 25, 2020AspirantI checked. I have 2 TP-Link TL-SG105
They do support green tech with the 802.3x
So that is the problem.- GMoGoody8Oct 25, 2020LuminaryThis could definitely be the case if your devices are on the 2.5.16 FW because that is where the issue was reported.
Netgear just recently released two new firmware revisions depending on your location. I have been monitoring to see if this issue had been resolved or not.
My current setup won’t allow Ethernet Backhaul. I am moving at the end of the year and wanted to use it so I have been watching the forum.
