GMoGoody8's avatar
GMoGoody8
Luminary
Jan 23, 2021
Ethernet Backhaul Update
FURRYe38, Finally settled into the new place and have an update on our Ethernet Backhaul Discussion from https://community.netgear.com/t5/Orbi/Orbi-Ethernet-Backhaul-Compatible-Switches/td-p/1913276
With the newest firmware I have no issues with Netgear unmanaged switches that support green Ethernet. Though I made sure to only have one switch between the router and satellite.
RBR --> Home run to patch panel --> Netgear GS108 --> home run to RBS
1 Reply
  • FURRYe38's avatar
    Good to hear. Im currently using that same model switch and works for both Orbi AC and AX systems.
    Mark your threads as solved so others will know.
    Enjoy. :smileywink:
