HomeBrewJoe
Sep 25, 2019Aspirant
Ethernet backhaul via MoCA 2.0, how do I set it up?
Hello, I currently have an Orbi pack i believe called RBK44 which contains one AC2200 router and three satellites. My current home setup is as follows: - FiOS gigabit service, FiOS gateway (MoC...
HomeBrewJoe
Thanks I was just drawing out a diagram of how I would set this up correctly and I think I can make it work with what I have.
Current setup is the following (see attachment Orbi setup1)
Im okay with the current setup as the wireless backhaul is pretty solid but if I can improve performance by wiring one satellite backhaul at zero cost, why not?>
HomeBrewJoe
Proposed setup (see attachment Orbi setup2).
