molec
Jun 14, 2018Guide
Ethernet backhaul, WAN port or LAN port, magenta ring led on router
I'm trying to resolve some conflicting suggestions I have read (mainly on this forum).
So my setup is a RBR50 with 2 RBS50 satellites, one of them using ethernet backhaul. I use a different box...
- Jun 14, 2018
You can connect the Orbi while in AP mode the main host router using either WAN or LAN. NG for some reason while in AP mode still depends on the use of the WAN port connected to the main host router. Technically, using any of the ports in back will be ok. It's just the FW and the detection of the WAN port for the top LED isn't quite designed right to handle the use of other LAN ports. It defaults to detecting the use of the WAN port. So you can use the WAN port if you like to satisfy the top LED behavior or live with the top LED being ON all the time giving you false positive on the LED. Nothing to worry about.
Any HW accelleration is disabled on Orbi. Only when in router mode is it enabled and only if you don't enabled the speedtest app, Traffic Meter and Access controls.
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, LAN to LAN and configure AP mode on the Orbi router.
Jun 14, 2018Guru - Experienced User
Modem Combo Units:
Couple of options,
