garyslaben
Jan 11, 2018Follower
Ethernet Backhaul
I originally set up the system with wireless backhaul. Just now reconfigured as wired. Router status still shows satellites connected as 5G. Do I need to reset the satellites or perform some other...
DarrenM
Jan 12, 2018Sr. NETGEAR Moderator
You need firmware version 2.1 or newer on your orbi for ethernet backhaul you can find the firmware on the the Support page.
http://www.netgear.com/support/product/orbi.aspx
DarrenM
