garyslaben
Jan 12, 2018Follower
Ethernet Backhaul
I originally set up the system with wireless backhaul. Just now reconfigured as wired. Router status still shows satellites connected as 5G. Do I need to reset the satellites or perform some other...
vseera
Feb 01, 2018Guide
Haha, I have disabled something called "redirects" on the other access point on my network.
However, I am waiting to try out just disconnecting everything and seeing if just the wired connection between the router and satellite works. If it does, then it could be that the AP is being incompatible.
Will report back! Thank you so much for all the help till now!
psrtx1
Feb 01, 2018Star
Let me know if you get a stable wired backhaul. I have never been able to get wired backhaul to work without crashing the router.
- vseeraFeb 01, 2018Guide
Haha, that's not very comforting! But yes, I will. If it doesn't work, I may look into using a lot of different access points and just wiring everything up. But it's a pain and I'd rather just simplify and try and use this.
Will update here as soon as I can!
- vseeraFeb 03, 2018Guide
Ok so a quick update. I turned off all wired devices connecting to the router and satellite and only kept the wifi ones on.
Then I turned off both router and satellite, attached the cable and turned both on. It acted funny for a bit but then gave me a stable connection. I waited about 5 minutes for it to go down, but it didn't.
I then connected my other router (working as a switch with dhcp disabled) and quickly disabled anything I could think of which wasn't necessary like Redirects, TR-069, UPnP IGD, etc.For now, it seems to be working fine. I have tested transfers over the ethernet and they work to be around 100MB/s which is great.
Internet seems stable too. Seems like I may have finally fixed it!
- ChillybFeb 12, 2018Aspirant
hey there - i am having same exact issues you had. did your solution work long term?
- vseeraFeb 13, 2018Guide
Hi,
Yes it does seem to be working fine. I think the problem may have been some sort of incompatibility with the other switch on the network. However, after disabling almost everything on it, it seems to be stable enough.
Enough people have situations like mine and yours to say that the firmware is far from complete and bug free, but with a little bit of luck you should be able to get it working too.
Let us know how it goes for you!
