iantr
Sep 15, 2020Aspirant
Ethernet cable from satellite? And should I change channel?
I'm sorry if this is a silly question: I have a RBR20 plus one satellite. I've found this setup quite unstable and unreliable since installing. It seemed to get a bit better when I turned off the wif...
Mstrbig
Sep 15, 2020Master
WIFI should be stable on your system. What could cause issues is satellite too far or close to router or other satellite, Definitely WIFI interference.
So make sure your RSSI signal is not too high and change both the 2.4Ghz and 5Ghz channels to ones less used.
