tiepa
Oct 31, 2017Aspirant
Ethernet connection for second satellite
hello is it possible to have the orbi router connected to the internet then the 1st satellite connected via the dedicated wifi signal then a third router/satellite connected to that satellite via...
tiepa
Thanks for the reply
I will certainly try that .
Another question I don’t understand why you can’t have the router with internet in and out ports wireless connection to the satilite with internet ont ports cable connection to a 3rd unit ( a router model ) with internet in port . Is the internet in connection on the 3rd not the same as the first router ?
Sorry but that seems logical to me .
Kind regards
Tiepa
Kind regards
Tiepa
Streak2
Oct 31, 2017Master
Once your Orbi is properly set up, then every ethernet port is internet enabled. ie. you can connect any device to any port on the router or satellite.
It's just that you can't link Orbi devices via cable, they have to be sync'd via wireless.
- tiepaOct 31, 2017AspirantHi thanks again for the reply
Ok cool so I could as a solution connect a third party router to end of my Ethernet cable ? To create another Wi-fi ?
I will leave you be after this question I promise
Thanks
Tiepa- Streak2Oct 31, 2017Master
Yes. You could run a cable from the nearest ethernet port (coud be the nearest satellite) to the garage and then plug in a wireless device there.
You could also try a powerline adapter running the signal via the mains.
So, ethernet from satellite to one end of adapter plugged into the mains.
Other end of adapter plugged into power outlet in the garage.
fantastic problem solved.
although would be nice to have the wired ethernet connection to another orbi for the true
seemless experience. hopefully in the near future.
thanks again for your help on this
tiepa
