Kilmartins
Mar 22, 2018Aspirant
Ethernet connection to Android box
I have my Orbi set up as this: Virgin router is connected to my Orbi router and then I have 2 other Orbi satellites wirelessly set up around the house. What I would like to do is plug my Android box...
Kilmartins
Hi,
Thanks for your reply.
I want to connect the box to the 1st satellite not the Orbi router. Can this be done? I am assuming it can, otherwise why would the satellites have Ethernet ports.
Regards
Mar 22, 2018Guru - Experienced User
Yes, you can connect any ethernet supported device to the back of the satellite after it's fully configured and set up.
