jp4120's avatar
jp4120
Guide
Jul 16, 2022
ethernet connections dropping plus firmware updates failing
purchased from amazon july 2018. - model sold as RBK33 (not an option on the model dropdowns) NETGEAR Orbi Tri-band Whole Home Mesh WiFi System, with Wall Plugs (RBK33)   i have switched ethernet ...
  • jp4120's avatar
    jp4120
    Jul 16, 2022
    the flashing light is on the computer connection.
    i switched ethernet cables and i googled a bit about troubleshooting my Acer Aspire computer.
    based on that i went into device manager and enabled a network access driver (not sure how it got disabled)
    then i rebooted everything and waited about 30 minutes and now the ethernet connection is working.
    so the issue may not have been Orbi after all.
    2nd issue today was my older HP laptop was suddenly 'blocked' from the internet by the Orbi router.  I must have done something while troubleshooting the first issue because this was the first time this ever happened.
    per Orbi instructions you should be able to allow access or unblock devices but this would not work for me.  So i found via google a way to reset/renumber my MAC address on my laptop and this resolved this 2nd problem.
