ji0906
Sep 24, 2018Aspirant
Ethernet is not working on main router (but working on Satellite)
Hello,
I just installed Orbi (RBK50). It was very easy to install, but one problem. "Ethernet port on the main router" seemed not working. I connected my laptop and other items to the Ethernet...
ji0906
Thank you for the comment!
When I test, I just connect one computer and removed other LAN devices from LAN ports on the Orbi router. I also used the same laptop and cable when I did the test ... I was able to connect the internet via Satellite, but not able to connect the internet through main Orbi router.
I will double check my computer setting and cable again.
Thank you!
Sep 24, 2018Guru - Experienced User
What other devices do you have connected to the LAN ports on the router?
- ji0906Sep 24, 2018Aspirant
Currently nothing.
Ideally those devices on the main router.
- Powerview Hub which controls blind (and needs to connect via Ethernet). Currently connected via Satellite, but would like to connect on the main router.
https://www.hunterdouglas.com/operating-systems/motorized/powerview-motorization/works-with
- The Blueray player which only has the Ethernet port.
Thank you!
