ji0906
Sep 24, 2018Aspirant
Ethernet is not working on main router (but working on Satellite)
Hello,
I just installed Orbi (RBK50). It was very easy to install, but one problem. "Ethernet port on the main router" seemed not working. I connected my laptop and other items to the Ethernet...
ji0906
Sep 26, 2018Aspirant
Thank you!
This happens to all Ethernet port on the main router. I tried with another device (such as Apple TV), but it can't connect internet.
As you recommended, I will do t factory reset and set it up again. he
Thank you!
Jun
Sep 26, 2018Guru - Experienced User
Let us know the results...
- ji0906Oct 04, 2018Aspirant
Sorry for the belated reply.
I reset router completely (factory reset) and set it up again ... but Ethernet still doesn't work.
I also installed the newest Firmware which was released yesterday, but the result was the same.
I felt like that my router is incipient failure ... so I might ask shop to change it.
I'll keep posted. Thank you!
- FURRYe38Oct 04, 2018Guru - Experienced User
Ya, sounds like the ports or the router portion of the Orib is bad. Get it replaced.
