71cuda
Sep 11, 2019Aspirant
Ethernet Lights on cable modem port are amber
I occasionally have connectivity issues between Orbi and my cable modem. For some reason, orbi could not get an ethernet address from my cable provider. But when I plugged my TV into the ethernet p...
71cuda
Sep 13, 2019Aspirant
This is my status with the modem port showing the solid orange light.
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time WAN 1000M/Full 2458640 17799435 0 3962 51011 2:43:18 LAN 100M/Full 6541942 1038487 0 11969 1147 0:01:47 WLAN b/g/n 400M 838705 458 0 3 0 23:22:06 WLAN a/n/ac 866M 627920 38814 0 3542 34 23:21:51 WLAN Backhaul 866M 1927440 1106728 0 13197 1800 23:21:51
Sorry about the bad formatting. For some reason the HTML format would not hold up in the reply window. WAN is 1000mb/s while lan is 100mb/s
CrimpOn
Sep 13, 2019Guru - Experienced User
Yes, HTML doesn't copy and paste very well. Still, the stats page is pretty clear.
The WAN port (from Orbi to modem) is at 1000mb (1 gig), and
The LAN port is at 100mb.
So, solid amber means 1000mb. Problem solved!
