71cuda
Sep 11, 2019Aspirant
Ethernet Lights on cable modem port are amber
I occasionally have connectivity issues between Orbi and my cable modem. For some reason, orbi could not get an ethernet address from my cable provider. But when I plugged my TV into the ethernet p...
71cuda
Sep 13, 2019Aspirant
This is my status with the modem port showing the solid orange light.
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time WAN 1000M/Full 2458640 17799435 0 3962 51011 2:43:18 LAN 100M/Full 6541942 1038487 0 11969 1147 0:01:47 WLAN b/g/n 400M 838705 458 0 3 0 23:22:06 WLAN a/n/ac 866M 627920 38814 0 3542 34 23:21:51 WLAN Backhaul 866M 1927440 1106728 0 13197 1800 23:21:51
Sorry about the bad formatting. For some reason the HTML format would not hold up in the reply window. WAN is 1000mb/s while lan is 100mb/s
Sep 14, 2019Guru - Experienced User
Did you happend to look at the modems user manual to see if it had LED behavior information?
Sounds like this isn't a problem.
71cuda wrote:This is my status with the modem port showing the solid orange light.
- 71cudaSep 14, 2019Aspirant
I have been unable to locate a manual for this modem as of yet.
I agree that the speeds seem fine with Orbi plugged in. It does take forever and a day for Orbi to get an IP address from the modem compared to the TV being plugged into the modem. The tv gets an address instantly and it might take an hour for Orbi to get an address and dns. WHen the TV is plugged into the modem, the port light is solid green. WHen Orbi is plugged in, it is amber. Maybe that is just the way it is. Not sure. I was under the impression that green would be good and any other color would indicate a problem.
- FURRYe38Sep 15, 2019Guru - Experienced User
Does this manual have any good information?
