clrd4approach
May 07, 2020Aspirant
Ethernet ports not working when internet is down
I have a orbi RBR50 setup on ppoe (we have CL) we had a internet outage the other day and during the outage we noticed that the lan ports did not seem to be working. We have a fire tv recast on our ne...
- May 08, 2020If you run a Ethernet cable from from the orbi back to the modem and use one of the lan ports you can access the modem GUI to monitor your dsl stats so you would have 2 Ethernet cables to and from the modem one in the wan and one in the lan
May 07, 2020Guru - Experienced User
Can you access the RBRs web page with a wired PC when this happens at 192.168.1.1?
Built in router here by chance? If so,
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- clrd4approachMay 07, 2020AspirantYes I have it set up on transparent bridging, I had to take the gateway with built in modem and turn off transparent bridging and unplug the the orbi system and just use the gateway with built in modem. I do not have a double NAT. The gateway is a zyxel gateway C3000. I have changed the orbi login to 192.168.0.2 so that if I need to get into the gateway I can.
- tomschmidtMay 07, 2020Virtuoso
As an experiment, I unplugged the CAT6 cable from my cable modem to the WAN port of my Orbi RBR50, thus disabling connectivity to the internet. My local network continued to work, both wired and WiFi systems. I could still access my NAS storage, IP cameras, TiVo (local recordings and over-the-air TV broadcasts) and other local devices. I do not have a FireTV recast so perhaps it depends on the internet. I do have several FireTV sticks, which of course did not work since they could not access the Internet for streaming services.
- FURRYe38May 08, 2020Guru - Experienced User
FYI, when you bridge or use Transparent bridging on those modems. the modems web page becomes inaccessible. Thats normal for those modems. If you disabled Transpartent briding, then you are in a double NAT condition.
clrd4approach wrote:
Yes I have it set up on transparent bridging, I had to take the gateway with built in modem and turn off transparent bridging and unplug the the orbi system and just use the gateway with built in modem. I do not have a double NAT. The gateway is a zyxel gateway C3000. I have changed the orbi login to 192.168.0.2 so that if I need to get into the gateway I can.- clrd4approachMay 08, 2020AspirantIf you run a Ethernet cable from from the orbi back to the modem and use one of the lan ports you can access the modem GUI to monitor your dsl stats so you would have 2 Ethernet cables to and from the modem one in the wan and one in the lan
