Deckard22
May 15, 2018Aspirant
Ethernet ports on satellite disconnects
Hello! I've had my Orbi for just over a month now. I live in a three story stacked townhouse, with the router on the second floor and the satellite on the first floor. I have a PS4 plugged into the e...
- Jun 06, 2018
Lets try clearing the browser cache or try using IE11 or FF browsers. Use the routers web page ERASE funtion with in the UI or if you use the button in back, hold in the button until the TOP LED turns amber, then release. Lets use the ERASE funtion in the UI.
For not lets see if anything happens or not. If it does again, try the erase in the UI.
May 15, 2018Guru - Experienced User
Whats the distanct between the satellite and router?
Has the satellite been rebooted after the FW update?
Try a factory reset on the satellite and re-add it to the router.
Try using a manual channel 1, 6 or 11 on 2.4ghz and any unused channel on 5Ghz.
