Deckard22
May 15, 2018Aspirant
Ethernet ports on satellite disconnects
Hello! I've had my Orbi for just over a month now. I live in a three story stacked townhouse, with the router on the second floor and the satellite on the first floor. I have a PS4 plugged into the e...
- Jun 06, 2018
Lets try clearing the browser cache or try using IE11 or FF browsers. Use the routers web page ERASE funtion with in the UI or if you use the button in back, hold in the button until the TOP LED turns amber, then release. Lets use the ERASE funtion in the UI.
For not lets see if anything happens or not. If it does again, try the erase in the UI.
Deckard22
Thanks for the tips! Router and satellite were both updated with the lastest firmware at the same time (when I bought them; I don't believe there's been a firmware update since). The satellite is downstairs from the router, about twenty feet in a straight line. The satellite lit up blue when I paired it with the router.
You think this is a firmware issue potentially? It happens pretty sporadically...not every day or anything. I'll try your tips out. Thanks again for responding!
May 15, 2018Guru - Experienced User
20 feet is a bit too close, 30 feet minimum to begin with.
I would try rebooting both router and satellite. If still happening, try a factory reset on both units then set up from scratch. I would move the satellite out farther though first.
- Deckard22May 15, 2018Aspirant
I might try moving the satellite...although my townhouse has concrete floors and the signal generally can't reach downstairs too well (and struggles to reach the third floor; in fact I've bought ANOTHER satellite for the third floor of our house).
I'll try rebooting the router and satellite as well. Thanks again for your help!
- FURRYe38May 15, 2018Guru - Experienced User
Ok, that would be an issue as well. Concrete will impact wireless. 20 feet maybe ok. I would move the 3rd floor closer though.
Try swapping satellites as awell, if you don't see the issue again, then maybe you have a bum satellite.
Disable Daisy Chain as well.
I think Daisy Chain is off, but I'll check that as well; won't need it on anyway as the router will be situated between both satellites. Curious: have you seen this problem before, and has actually doing these various things really fixed it, or should I really just be prepared to return and exchange my system? Cheers!
- Deckard22May 25, 2018Aspirant
Quick question: how do you reboot the router and the satellite? Do you simply reboot the router and the satellites reboot automatically? Thanks in advance!
- FURRYe38May 25, 2018Guru - Experienced User
You can reboot the router from the Advanced/Status menu. There is a REBOOT button there. The Satellilte doesn't have this I believe so just power it off for 10 seconds then back on. Same for router if you wanna power cycle it.
- Deckard22May 29, 2018Aspirant
Thanks!
