Deckard22
May 15, 2018Aspirant
Ethernet ports on satellite disconnects
Hello! I've had my Orbi for just over a month now. I live in a three story stacked townhouse, with the router on the second floor and the satellite on the first floor. I have a PS4 plugged into the e...
- Jun 06, 2018
Lets try clearing the browser cache or try using IE11 or FF browsers. Use the routers web page ERASE funtion with in the UI or if you use the button in back, hold in the button until the TOP LED turns amber, then release. Lets use the ERASE funtion in the UI.
For not lets see if anything happens or not. If it does again, try the erase in the UI.
Brain29
May 16, 2018Apprentice
its a bug with the firmware -- the beta seems to correct this .. contact support and ask for the beta firmware
Deckard22
May 17, 2018Aspirant
Thanks for your reponse...this is the first I've heard of this! Is it just the most recent version of firmware that has causd this? And would you mind letting me know where you found this out? Just wondering, and thanks again!
