Deckard22
May 15, 2018Aspirant
Ethernet ports on satellite disconnects
Hello! I've had my Orbi for just over a month now. I live in a three story stacked townhouse, with the router on the second floor and the satellite on the first floor. I have a PS4 plugged into the e...
- Jun 06, 2018
Lets try clearing the browser cache or try using IE11 or FF browsers. Use the routers web page ERASE funtion with in the UI or if you use the button in back, hold in the button until the TOP LED turns amber, then release. Lets use the ERASE funtion in the UI.
For not lets see if anything happens or not. If it does again, try the erase in the UI.
May 17, 2018Guru - Experienced User
Hope something works out for you...keep us posted.
- Deckard22May 23, 2018Aspirant
I've only switched the ethernet port I was using for now...it disconnected again. I will attempt a reset of the system and see if that does it next; I'm trying things piecemeal rather than rebooting/factory reset/etc. I've read that the beta firmware seems to fix my issue...how do I get my hands on it, or when will the new firmware be released?
- FURRYe38May 23, 2018Guru - Experienced User
If your on v2.1.4.10, then your at most current version. You can contact NG support and see if there is anything beta available.
I would try a factory reset and set up from scratch as last resort.
Oof...hope it doesn't come to that. Got some other advice from support re: tinkering with settings. I'll try that too. Thanks!
