Deckard22
May 15, 2018Aspirant
Ethernet ports on satellite disconnects
Hello! I've had my Orbi for just over a month now. I live in a three story stacked townhouse, with the router on the second floor and the satellite on the first floor. I have a PS4 plugged into the e...
- Jun 06, 2018
Lets try clearing the browser cache or try using IE11 or FF browsers. Use the routers web page ERASE funtion with in the UI or if you use the button in back, hold in the button until the TOP LED turns amber, then release. Lets use the ERASE funtion in the UI.
For not lets see if anything happens or not. If it does again, try the erase in the UI.
May 29, 2018Guru - Experienced User
Let us know the status of any progress...
- Deckard22Jun 06, 2018Aspirant
Did my factory reset, although I'm not sure it worked (didn't reset my SSID or password like it was supposed to). Hasn't dropped yet...but it's only been a few days. Will keep you posted.
- FURRYe38Jun 06, 2018Guru - Experienced User
Should have reset SSID and PW. Should have started with a set up wizard. How long did you hold in the reset button or did you use the web page UI to ERASE the settings?
I'll post the steps below. I followed them to the letter. I didn't delete any settings in the Web UI, but it was supposed to reset to the factory settings and it didn't:
1. First, please unplug the Orbi router from your modem(disconnect the Ethernet cable) from the Internet port on the Orbi router. This is to make sure that the Orbi router will properly reset.
2. To reset the Orbi router, please use a paper clip and press and hold the router's reset button for 20 seconds. After 20 seconds, release the reset button and unplug the power cord of the router for 10 seconds and re-connect it back to the router. Reset the satellites as well. Press and hold their reset button for 15 seconds. You can reset them one at a time.
3. Wait for about a minute and use a laptop, desktop or smart phone to detect the Orbi router's default Wi-Fi name(Wi-Fi password labeled on the router). You can also wired a computer to the Orbi router using an Ethernet cable. Once your device detects the default Wi-Fi name of the Orbi, please connect your device to it and then connect the Ethernet cable from the modem back to the Internet port(yellow port) on the Orbi router.
4. On the device connected to the Orbi network, please open a browser and go to www.orbilogin.net/com and you should see a Welcome to Orbi page. Just click next and follow the onscreen instructions to re-install the Orbi.
