dogbert88
Mar 28, 2019Aspirant
Ethernet ports
I have tried hooking 2 different devices (smart TV and Arlo security cameras) to one of the ethernet ports on the back of my satellite and neither device recognizes the ethernet connection as a wired...
- Mar 28, 2019
Check LAN cabling between satellite and devices. Use good quality cables. CAT6 is recommended.
Try connecting then to the base router to see if they connect there.
dogbert88 wrote:
I have tried hooking 2 different devices (smart TV and Arlo security cameras) to one of the ethernet ports on the back of my satellite and neither device recognizes the ethernet connection as a wired connection. Am I doing something incorrectly? Thanks.
CrimpOn
Mar 29, 2019Guru - Experienced User
The TV is too large to carry around, but what happens when the Arlo is plugged into the router LAN ports? i.e. if the Arlo connects to the router, but not to the satellite, then the topic may belong here.
