dogbert88
Mar 28, 2019Aspirant
Ethernet ports
I have tried hooking 2 different devices (smart TV and Arlo security cameras) to one of the ethernet ports on the back of my satellite and neither device recognizes the ethernet connection as a wired...
- Mar 28, 2019
Check LAN cabling between satellite and devices. Use good quality cables. CAT6 is recommended.
Try connecting then to the base router to see if they connect there.
dogbert88 wrote:
I have tried hooking 2 different devices (smart TV and Arlo security cameras) to one of the ethernet ports on the back of my satellite and neither device recognizes the ethernet connection as a wired connection. Am I doing something incorrectly? Thanks.
ekhalil
Mar 29, 2019Master
Can you see any wireless device attached to the Satellite in "Attached Device" in the web GUI or Orbi app?
It looks to me that you could have backhaul issues and therefore no devices (wired nor wireless) are being attached to the Satellite?
