dogbert88's avatar
dogbert88
Ethernet ports
I have tried hooking 2 different devices (smart TV and Arlo security cameras) to one of the ethernet ports on the back of my satellite and neither device recognizes the ethernet connection as a wired...
  • FURRYe38's avatar
    Mar 28, 2019
    Check LAN cabling between satellite and devices. Use good quality cables. CAT6 is recommended.
    Try connecting then to the base router to see if they connect there.
    dogbert88 wrote:
    I have tried hooking 2 different devices (smart TV and Arlo security cameras) to one of the ethernet ports on the back of my satellite and neither device recognizes the ethernet connection as a wired connection.  Am I doing something incorrectly?  Thanks.
