dharmagurl's avatar
dharmagurl
Follower
Jan 21, 2020
Ethernet ports?????
RBR10 - Orbi Dual-band AC1200 Mesh WiFi Router(RBR10)
I need to plug in a VOIP phone and there are NO ethernet ports on this??  am I missing something?  seems really odd not to have extra ethernet ports????
1 Reply
  • CrimpOn's avatar
    CrimpOn
    The RBR10 has one ethernet port to connect to the modem and one ethernet port to connect to "anything else."  The satellites have no ethernet ports at all.  This is the least expensive mesh Orbi system.  The data sheet makes this pretty clear: https://www.netgear.com/images/datasheet/orbi/RBK12.pdf The RBR50, in contrast, has three local ethernet ports on the router and four ethernet ports on each satellite.
    That single port on the RBR10 router is clearly designed to allow connecting an inexpensive ethernet switch (8 ports for $25 is typical).  If the VOIP phone is not located near the router, then this is the wrong WiFi system.  Take it back.
