Th3-0n3
Jan 12, 2019Tutor
Slow wifi speed.
I have a netgear cm1000 for the modem connected to my netgear nighthawk R7800 router my service is with comcast/ xifnity 400 download 10 upload. When I connect my PC to the modem I get the full 400. W...
- Jan 12, 2019
WMM should be enabled, not disabled
you should roll back the firmware to .52 as both .58 and .60 have wifi problems NG needs to address
Th3-0n3
Jan 12, 2019Tutor
Thanks I'll check that out also what other router would you recommend in case I need to get one?
myersw
Jan 12, 2019Master
Right now I have gone up to the next level and running Ubiquiti Unifi gateway (router) with Unifi AP's these then to be a more comercial product set and need some network knowledge to setup. Therefore I am not really running what I would recommend to the average Netgear forum member. I have over 20 years experience in routers and networks.
I watch forums folks have had good luck with Asus RT-AC86U similar to the r7800 and some Linksys. That is about all I have in the recommended area. Sorry I cannot be more specific.
- Th3-0n3Jan 12, 2019TutorThanks I'll keep that in mind.
