Nagron447
Jul 15, 2019Aspirant
Ethernet speeds via Orbi
Hi Guys, I recently purchased and installed the Orbi Wifi system, as the Router provided by my ISP would constanly drop Wifi connections on us. It was a brand new Netcomm Router that was provided...
- Jul 16, 2019
I restarted the ONT and Modem and problem solved. Back to 800+ mbps.
Jul 15, 2019Guru - Experienced User
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
What do AP mode configuration on the Orbi produce for you?
- Nagron447Jul 15, 2019Aspirant
I enabled AP mode when I set up the Orbi. So the same 500mbps speed.
- Nagron447Jul 16, 2019Aspirant
- FURRYe38Jul 16, 2019Guru - Experienced User
Glad it's working now.
Please mark your thread as solved so other will know.Enjoy. :smileywink:
