Mike199
Dec 30, 2020Aspirant
EUFY 30C Robovac
I have a new EUFY 30C Robovac and it will not connect to RBR40. The Eufy 30C Robovac says it will only connect to 2.4 MHZ. Any help is greatly appriciated.
- Dec 31, 2020I finally connected to the EUFY30C Robovac RBR40 by moving Eufy 30C off its charging base and put the unit on the kitchen chair. Setting next to it with my iPhone I ran the setup app again and “WALLA WALLA” it connected.. I had previously tried everything recommended by the manufacture of EUFY and NETGEAR nothing would work. I was ready to send the Eufy vacuum back but I used the the method I described and it finally somehow it worked... Wow all this and seven hours later...
alokeprasad
Dec 31, 2020Mentor
Ah! Cool! I did,'t think of stopping the broadcast and forgetting the current SSID on the client device as a way to force connections to the specific frequency.
FWIW, Roomba establishes its own temporary 2.4 Ghz WiFi network for initial setup (when you send the home WiFi credentials to it). Worked great w the Orbi and Nighthawk routers before that.
Dec 31, 2020Guru - Experienced User
Good info...hope this helps get them going.
