Thisjustin02
Jan 10, 2019Aspirant
Every 2-3 days I lose 90% of my speed on devices connected to the satellite
I've had the the RBR50 for a little over a month. Every 2-3 days, I lose 90% of my speed on any device connected to the satellite. Making any change that reboots the network will speed things up agai...
Jan 29, 2019Guru - Experienced User
Did you try setting the power output levels on the Orbi from 100% to 50% and see if this changes anything. Being in a noisey or wifi congested environment can cause problems like this.
Thisjustin02 wrote:
It took ten days, but the issue is back. If I connect via ethernet to the satellite, I get full speed. So...I don't think it an issue with the main communicating with the satellite. Otherwise ethernet wouudn't work at full speed. This seems like a firmware issue or something.
Thisjustin02
Feb 09, 2019Aspirant
I disconnected my satellite since Netgear said there's a hardware issue and the main started doing the same thing. This is getting really frustrating.
