Thisjustin02
Jan 09, 2019Aspirant
Every 2-3 days I lose 90% of my speed on devices connected to the satellite
I've had the the RBR50 for a little over a month. Every 2-3 days, I lose 90% of my speed on any device connected to the satellite. Making any change that reboots the network will speed things up agai...
Feb 19, 2019Guru - Experienced User
Wifi congestion can be problematic if you live near many others with Wifi signals. Reason why you can lower the power. If it's working at 50%, try 75% to see if you notice any drops.
Thisjustin02 wrote:
I cut transmit power to 50% and so far so good. I lost about 50mbps, but haven’t seen any major drops yet. I’m not sure I love that I have to worry about any kind of degradation on a system I just bought two months ago, but we’ll see.
Thisjustin02
Mar 12, 2019Aspirant
I’m at 50% power now and the issue is still happening. I think I’m done. My hardware warranty isn’t up, but I’m not paying for support. I’m just going to buy a different product. It’s been nothing but trouble since I bought it.
- xQuestx3Mar 13, 2019Tutor
I get the same exact issue. I can go days at full speed wifi then all of a sudden it drops to under 10Mbps. I have the RBR40 with v2.3.0.28. I seems like a memory leak of some sort. once I reset the router it's back to normal for awhile. is the nvram overloaded? I've tried turing off and on daisy-chain beamforming mu-mmo and fast roaming always does it.
- FURRYe38Mar 13, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?Has a factory reset and setup from scratch been performed this the update?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
What WPA security modes are you using?Try enabling Beamforming and MIMO. Under Advanced Tab/Advanced Settings/Wireless Settings
What is the size of your home? Sq Ft? 1100 sq feet
What is the distance between the router and satellite(s)? Around 30 feet, says good connection on the satellite.
What channels are you using? I’ve tried auto, 1-11
Any Wifi Neighbors nearby? I’d say around 6-8 wifi around me.
What WPA security modes are you using? WPA2-PSK
Try enabling Beamforming and MIMO. Under Advanced Tab/Advanced Settings/Wireless Settings. I’ve tried on and off, and factory reset.
I’ve used other routers and custom firmware etc , and never experienced anything like this. I think it’s a memory issue in the router. I also see other people having the same problem. Why would ethernet get full speed?
Possible wifi interferences from neighboring wifi could be an issue.
Try this, turn OFF the satellite. Just run the RBR alone for a few days.
Set the power output of the RBR from 100% to 75% or 50% if you feel like it. Test this configuration for a few days. Test speeds wired and wireless right after making changes, then speed test in a couple of days.
Might try a manual FW re-load of the system, reset and setup from scratch as a last resort.
What device do you have connected to the Orbi system?
- Thisjustin02Mar 14, 2019AspirantI tend to agree, there has to be an underlying issue of some kind. I know WiFi inference can cause all kinds of crazy issues, but it doesn’t make sense that things connected to the satellite get full speed on Ethernet. The Orbi main doesn’t change channels when you restart it, so It doesn’t make sense that that temporarily resolves the issue either. I guess I can try replacing the main; I’ve already replaced the satellite and that didn’t help.
- FURRYe38Mar 15, 2019Guru - Experienced User
Let us know how its going.
