cmftblynu
Dec 10, 2017Star
EVERYTHING is broken after V2.1.1.12
I am seriously ticked at Netgear. This update has broken everything, we tried to play a local lan game last night and EVERYONE kept disconnecting. My sattelites are all disappering, and not showing...
cmftblynu
Dec 25, 2017Star
So we figured it out. This was not netgear at all, this is an issue with Andoid phones. Oreo pixel or pixel 2 causes mass chaos with the orbi network. We just turned off the phone and everything works perfectly again. This is totally what was causing issues.
- aazDec 25, 2017Virtuoso
Well, to be fair - it's still a netgear issue because no wifi device should be able to cause the router to crash, but at least with that knowledge you have a workaround until the firmware is fixed. I'd also say try turning off UPNP and fast roaming on your router and see if that helps with it working with Android on.
