Martin3105
Mar 28, 2020Aspirant
EX7300 connecting to Orbi?
Hello, we are trying to connect one netgear product with another. Which is EX7300 connecting to the Orbi, but it is not working. Is this possible, and has someone a solution? We tried all steps, but ...
Mar 28, 2020Guru - Experienced User
which firmware are you on?
version 1.0.2.144 fixed some issues with connections to orbi. If you're not on that, try installing it, factory resetting, and re-trying the install process.
If this doesn't work, describe in details where/whats failing during the process.
I'd also ask why you're adding a mesh extender to orbi? The whole benefit to orbi is the wireless backhaul to reduce throughput loss and increased latency that extenders have. Using a standard extender is going to drop the speed and increase latency by the very nature of how they work.
- Martin3105Mar 28, 2020Aspirant
Thanks, with Orbi we are on v2.3.5.32 firmware version. We do not have wifi in our backyard, although we have a satellite. The satellite is on top floor
- plemansMar 28, 2020Guru - Experienced User
Martin3105 wrote:Thanks, with Orbi we are on v2.3.5.32 firmware version. We do not have wifi in our backyard, although we have a satellite. The satellite is on top floor
Sorry. I should have specified. Firmware on the extender. That's the key.
You can addin satellites to orbi. Its half the benefit is how easily you can add satellites to expand coverage. There's even an outdoor satellite. RBS50Y
- plemansMar 28, 2020Guru - Experienced UserIf you've had the extender from prior, its worth seeing how well it works. But if its new, I'd check into adding an actual orbi satellite as you'll get better performance and better roaming.
Thanks a lot. I have a new obi and the "old" EX7300. But most likely, it is wise to buy another Orbi satellite, you say?
