mgolub
Jul 08, 2023Guide
Excessive Internet Usage
Starting the 1st of July, my internet usage jumped to 400GB/day. I average 2-300GB/month. I've looked through the devices and only see two that I'm not sure of and I've blocked them. I don't see w...
Jul 08, 2023Guru - Experienced User
What NG product model are you referring too?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
- mgolubJul 08, 2023Guide
What NG product model are you referring too? OrRB RBR50
What Firmware version is currently loaded? V2.7.4.24. I checked for updates, says it's the latest
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? ISP is Xfinity and I'm using a Motorola M86000 modem
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.All cables are good, rewired a couple of months ago and everything has been running just fine for 2 years. Internet usage bumped to 400GB/day starting 7/1. I'm trying to track down what device(s) could be the issue. This is a home network.
