mgolub
Jul 08, 2023Guide
Excessive Internet Usage
Starting the 1st of July, my internet usage jumped to 400GB/day. I average 2-300GB/month. I've looked through the devices and only see two that I'm not sure of and I've blocked them. I don't see w...
Jul 08, 2023Guru - Experienced User
What NG product model are you referring too?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
mgolub
Jul 08, 2023Guide
What NG product model are you referring too? OrRB RBR50
What Firmware version is currently loaded? V2.7.4.24. I checked for updates, says it's the latest
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? ISP is Xfinity and I'm using a Motorola M86000 modem
All cables are good, rewired a couple of months ago and everything has been running just fine for 2 years. Internet usage bumped to 400GB/day starting 7/1. I'm trying to track down what device(s) could be the issue. This is a home network.
