varase
Feb 05, 2018Guide
Excessive static definitions on RBK-53
Anyone notice that if you add too many static entries, DHCP seems to stop working?
martyfp
Feb 06, 2018Luminary
how many is "too many" ? I have something like 20 static IPs. I tend to apply a static IP to anything that never leaves the network, including the Satellite.
DHCP works fine for me.
- varaseFeb 06, 2018Guide
I put in about 14 or 15 and our iPhones stopped connecting - removed all the unnecessary ones and the iPhones came back.
Spooky.
- martyfpFeb 07, 2018Luminary
You could try getting the iphones to "forget" the network and then rejoin. That might kick them into life.
- varaseFeb 12, 2018Guide
Well, it seems like our iPhones start losing connectivity when I have more than eight static (I guess since I'm assigning addresses by MAC address that should be fixed-addresses) defintions.
I've got a 192.168.1.2-99 dynamic range, and place the fixed addresses at >=100. Is that how NetGear's DHCP is supposed to work?
(I administer our enterprise's ISC DHCP and for that, host entries should be placed outside the dyanamic range to prevent collisions from powered-up fixed address clients).
